I know there must be an existing post on this subject, but I can't find it so bear with me.
I have a client with a three wire dryer recep. Due the wall construction it's not possible to get a 10/3 NM over there to change it to a 4-wire recep (without massive demo). The dryer is sitting right next to the water heater which is properly wired with 10/2 NM.
Can I tap the WH ground wire and run it over to the 4-wire dryer recep? (code reference please)
Can I ground using the water pipe of the washer? (code reference please) I have to check, but i believe the house has all copper piping.
Comment
