CSST Bonding
Chamuit
Grumpy Old Man
Texas
I've never had to do this. Does anyone have a picture of what this looks like? I've seen some illustrations but am having trouble visualizing.
Thanks!
Ohms law
Sioux Falls,SD
Is this not a mechanical code? Either way im pretty sure around here mechanical contractors bond it to the ufer ground or hire an electrician if no ufer ground is present.
One other thing I don't believe many contractors install is the thin wall pipe around my area, they install the thicker wall flexible pipe due to no bonding required and a less chance of developing pin holes from near by lighting strike.
Sent from my SM-G960U using Tapatalk
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
This is a gas code issue, not a mechanical code. Some areas allow non-electrical contractors to do the bonding while others don't. BTW, the thicker walled stuff does not require bonding per the manufacturer's instructions however, the gas code still requires it, I believe.
Chamuit
Grumpy Old Man
Texas
Thanks for the video Dennis.
So, you either bond the regular black gas pipe or the fitting on the CSST?
