73hemicuda
- Pennsylvania
I'm installing a new 240D/120CT to 480D 3 phase transformer. I have the ground from the primary side feed, the load side and the one to building steel on the lug bolted to the transformer enclosure. If I install the bonding wire from x6 to the enclosure lug, wouldn't this technically be bonded in two different locations since the ground from the primary side is already bonded at the main service entrance where it enters the building? Or is this correct?
