Shockedby277v
- Michigan
There is a metal grate on a floor trench drain around a swimming pool. It goes around the entire pool with lengths of 10' for the metal grate. The trench drain itself is plastic. Anyone find a clean & quick way to bond these before? I will need to run a jumper between each section I plan to penetrate the side of the trench drain to somehow bond it.
TIA
TIA
