hhsting
- Glen bunie, md, us
- Junior plan reviewer
I have cell tower structural reinforcement work in which certain parts of tower will have metal plates. The metal plates would be bolted to existing metal tower body surface on certain parts. The cell tower is grounded and bond thru grounding electrode mainly ground ring.
The metal plates are bolted to tower body and tower body is grounded and bonded so I assuming metal plates would be grounded and bonded thru bolts.
The question is does code require any special type of bolts or any special type of grounding and bonding for metal plates and work mentioned above paragraph?
Sent from my SM-G935U using Tapatalk
