Presumably you are asking about the National Electrical Code. If so, it would appear the answer depends on whether or not the manhole is under the exclusive control of the communications utility.
90.2 Scope.
(B) Not Covered. This Code does not cover the following:
(4) Installations of communications equipment under the
exclusive control of communications utilities located
outdoors or in building spaces used exclusively for such
installations
