Announcement
Collapse
No announcement yet.
Question
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Question
    I have Panel A which feeds fuel Panel F but in between has contactor which has 120VAC inverter to 24VDC. The 24VDC has 2-#14 awg to E stop switch for gas station.
    Would 24VDC part above require equipment grounding conductor?
    Sent from my SM-G935U using Tapatalk
    #2
    Where have I seen this question before?
    What will be the wiring method for the 24v?
    Master Electrician
    Electrical Contractor
    Richmond, VA
    Comment
      #3
      The question has already been asked in your other thread
      https://forums.mikeholt.com/showthre...light=gas+pump
      Please don't start multiple threads with the same question!
      [COLOR=navy]If you aim at nothing, you will hit it every time![/COLOR]
      Comment
      Working...
      X
