Announcement
Collapse
No announcement yet.
Ground question XFMR
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    New drawings submitted and my question is why is a ground not included between the transformer and 480volt gear. I drew in a green line where i feel the ground is needed. Thoughts/reasons why engineer left it out? Thank you Ground question.pdf
    #2
    That would be the supply side bonding jumper (SSBJ) and is required. It could be a metal raceway.
    Rob
    All responses based on the 2017 NEC unless otherwise noted
    Comment
      #3
      Great, so if these conductors were in EMT or Ridgid that would be sufficient. Can you supply me an article number.
      Comment
        #4
        250.118
        Roger
        Comment
          #5
          Roger 250.118 is equipment grounding conductors, does this relate to the supply side bonding jumper? Appreciate all the info
          Comment
            #6
            I should have also mentioned the last sentence of 250.30(A)(2)
            Roger
            Comment
            Working...
            X
