Announcement
Collapse
No announcement yet.
Ground wire
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Ground wire
    Sub panel without a ground wire
    #2
    Need more info and what is your question?
    Roger
    Comment
      #3
      Are you suggesting it does not have a grounding electrode conductor? Or an equipment grounding conductor? Or a grounded conductor?
      If it is a panel fed from another panel it generally does not require a grounding electrode conductor (unless in a separate structure).
      If it uses metallic conduit or EMT the EMT or conduit can serve as the equipment grounding conductor.
      If there are no L-N loads no grounded conductor is actually required.
      Bob
      Comment
        #4
        Roger
        I agree, sub-panel pre-2008 and separate structure no EGC required.
        Rob
        All responses based on the 2017 NEC unless otherwise noted
        Comment
        Working...
        X
