Announcement
Collapse
No announcement yet.
Ground Riser
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Ground Riser
    Anyone know what you would use to tap off the # 500 vertical grounding conductor to go to the ground bar? T Tap?
    #2
    Mechanical or crimp connection?
    Rob
    All responses based on the 2017 NEC unless otherwise noted
    Comment
      #3
      something like this maybe?
      Click image for larger version
      Bob
      Comment
        #4
        Yes that is what I was thinking for a crimp connection. For a mechanical connection I would use a IPC type tap.
        Rob
        Comment
          #5
          I like the compression tap.
          Related question, what type of conduit is the 500 kamil in?
          Moderator-Washington State
          Ancora Imparo
          Comment
            #6
            Related question, what type of conduit is the 500 kcmil in?
            I'm guessing....EMT.
            Rob
            Comment
              #7
              EMT
              Comment
                #8
                Thank guys
                Comment
                  #9
                  If this is a GEC and the riser is EMT, the ends of the EMT need to be bonded to the 500 KCML See 250.68 (E), Since the dwg shows transformer I am pretty sure this is a GEC. You would be much better off using SCH 80 PVC for the conduit. Your bonding jumper for the ends of the EMT has to be 500 KCML. The size for the common grounding electrode conductor is not smaller than 3/0
                  250.30 (A)(6). At the end of that section is the requirements for the tap conductor connection. Not sure why 500 KCML is being used but there may be an engineering reason
                  Ancora Imparo
                  Comment
                    #10
                    One other comment, grounding conductor is not a code term...we get confused on grounding and bonding as we use the incorrect terms...
                    Ancora Imparo
                    Comment
                      #11
                      You're correct, this is actually a common grounding riser under 250.30(A)(6). A grounding hub can be used on the EMT to bond it directly to the riser. Not sure why anyone would spec 500 kcmil when #3/0 is all that's required.
                      Rob
                      Comment
                      Working...
                      X
