Announcement
Collapse
No announcement yet.
Propane Tank grounding.
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Do above ground propane tanks used to fuel LPG powered vehicles require bonding or grounding other than what I provide as an EG to the pump motor per NFPA 70?
    It will sit on a 4' concrete slab with 'mesh'. No footings. No rebar.
    Tom
    TBLO
    #2
    Been a long time since I done it. You are going to need some rigid conduit, some seal offs and the aforementioned EGC to the pump. That should cover it.
    If Billy Idol is on your playlist go reevaluate your life.
    Comment
      #3
      As Dave said, it's not necessary.
      Comment
      Working...
      X
