Announcement
Collapse
No announcement yet.
Grounding in 2 places?
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    I have a condo building I'm working on with 16 tenants. The meter/disconnect pack is in a basement closet. The service is 800 amps. The electrode grounding conductor comes out of the disconnect and goes underground to who knows what or where - it looks to be sized appropriately and is copper. There is not a gec to cold water - I could not find it and it may be pvc. The building was built in 1984 and is in Atlanta, Ga
    The feeders to each unit are 1/0 SER aluminum. The panels are mlo and have the neutral bar and eq gr. bars separate. For some reason someone ran a #4 gec from the eq grounding bar to the cold water at the water heater, which is a few feet away.
    This is not the first time or building that I have seen this set-up. I removed the #4 going to the water heater and I'm wondering if I need to put it back. I usually work on sing family dwellings.
    I'm just hoping somebody could help me out here if they know a reason for this installation
    Thank you!
    #2
    That # 4 is probably not doing much. IMO it won't hurt anything by leaving it.
    Rob
    All responses based on the 2017 NEC unless otherwise noted
    Comment
      #3
      Thanks but I already removed it. Unless anyone can think of why it should be there in the first place, I will leave it out
      Comment
        #4
        Sounds to me like that were bonding the metal water pipe system to the panel which won't do any harm.
        Rob
        Comment
          #5
          Thank you!
          See 250.104(A)(2). This often applies multi occupancies in one building.
          Comment
            #6
            That would be my bet as well.
            Roger
            Comment
            Working...
            X
