Hello all,
I encountered a old bank that has no grounding system. none other than a #2 cu being fed from the main water copper line. There is one main 400A 120/240v delta 3-phase MDP, 1- 200A 120/240v delta 3-phase sub panel, and 1- 100A 120/240v single phase subpanel. There are no bonding bushings installed, no main grounding electrode, building steel isnt bonded, cast iron waste pipes not bonded, no bond on natural gas lines, you get the picture.
I think this is a silly question. Can i install pipe clamps on the rigid and EMT conduits at each panel instead of bonding bushings so as to not be required to disturb operations or pay overtime?
