yukonjack_99674
- Alaska
Can anyone explain to me what is ment by nominal voltage? If you have a 120/240 service, is your nominal voltage the 120 legs to ground? or the 240? I do not understand how you can get 240 to ground. From what Ive read, the circuit is based on the equipment to be used. In other words, if you have 240volt heaters the circuit is considered 240v nominal yet what would be your reference point. You see nominal voltage all over the code book, I must have a thick head. Thanks
