Does anyone have any reccomendations on running HDMI cable in the wall? Does it need to be wall rated? I noticed they have some wall plate options, but I was thinking of just running it out a blank plate with a hole in it.
Either the hole would have to be good sized or be part of a split or slotted plate since you cannot add the connector yourself.
Interesting technology. CL2 rated cables for in wall use, pull or fish the cable first then add the terminations.I have used a system called rapid run. They use a few cables for many different uses and the different jacks for the ends. The cable can be purchased in plenum if need.
http://www.rapidrun.com
