Announcement
Collapse
No announcement yet.
Data Cable Labor
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Data Cable Labor
    Recently changed contractors and looking at the DB they are using, data cable labor looks wrong.
    All cable whether single or say 3 cables together have the same labor.
    So 7.4/m for all cables.
    I found where we should be adding labor to the first wire labor as you add more cables.
    So first cable is the 7.4, the adder for cable #2 is .25 and the third is .5.
    So the pull for three cables has 7.9/m as the total labor.
    Does that sound right?
    Thanks,
    Vic
    #2
    Data Cable drops here are $350-450 per drop. termination extra . Resi well thats a different story , same old thing get the electrician to do them for 60.00 each
    " DON'T use low prices as your selling advantage. The advantage disappears the moment someone dumber than you offers a lower price "
    Doug
    Comment
      #3
      drops here are a third of that, including termination and certification.
      a flat rate of $125 ~ $175 is pretty common.
      ~New signature under construction.~
      ~~~~Please excuse the mess.~~~~
      Comment
        #4
        We do them for no less than $200.00 per drop, and we'll probably bump the pricing up in the near future. $450 per drop would be some good times!
        Comment
          #5
          everyone has their own pricing structure.
          many contractors are horribly expensive for some things and dirt cheap on others. the end result tends to be a wash.
          Bob
          Comment
          Working...
          X
