Announcement
Collapse
No announcement yet.
12/4 In Device Box
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    12/4 In Device Box
    Is it a PIA to splice through 12/4 in device box? Case in point, if you have 3 receptacles next to each other all on separate ckt and allowed to share neutral and you pull a 12/4 to the first device.
    #2
    It depends on the cu. in of your box but it will be tight. You may be able to if your box has a minumum 27 cu.in. This allows a 12/4 and a 12/3 with a device grounds and a clamp-- not sure what you are using. Personally I would avoid it and put a jb above, if possible
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
    Comment
      #3
      With a 3 gang box you will have plenty of room if there is just one 12/4 cable.
      Rob
      All responses based on the 2017 NEC unless otherwise noted
      Comment
        #4
        The PIA factor does not into play in deciding where and when to splice, it comes from dealing with instructions someone who is not there and has no idea what you are dealing with trying to tell you what to do.
        If Billy Idol is on your playlist go reevaluate your life.
        Comment
          #5
          3 gang box? Talking about 3 receptacles a few feet apart. So 4x2-1/8 box for each recept.
          Sent from my SM-N960U using Tapatalk
          Comment
            #6
            Well, cubic inches aren't the problem. With a plaster ring you've got more than 32 - 33 cubes and, by my count, you need 25.
            Are you pigtailing, or landing a lot of conductors on the device?
            Another Al in Minnesota
            Comment
              #7
              Got it, but you did say "if you have 3 receptacles next to each other" which sounded like a 3-gang to me.
              Rob
              Comment
                #8
                Is this 3 120 volt circuits from a 3 phase service?
                Sent from my RCT6213W22 using Tapatalk
                Comment
                  #9
                  Yes
                  Comment
                    #10
                    That is how I would do it.
                    Rob
                    Comment
                      #11
                      Use a 4'' square box for your first device with a 1-gang ring., and normal device box for your next two devices.
                      Comment
                      Working...
                      X
