Announcement
Collapse
No announcement yet.
Switching
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Switching
    So is a switch loop and a switch leg the same thing? I know when you bring power to the light then you have a switch loop down to the light switch and need a neutral in the box. But if you bring him power to the light switch do you still have a switch loop or just a switch leg up to light? Thanks
    #2
    A switch leg is the switched hot conductor going from the switch to the light. A switch loop would be a hot from the light down to the switch and the switch leg back up.
    -Hal
    Comment
      #3
      -Hal
      So when you have a switch loop you don't have a switch leg?
      Comment
        #4
        Yes you do have a switch leg. The wire that returns to the light to turn it on is a switch leg-- you always have that-- The switch loop takes the hot conductor down to the switch and then takes the switch leg up to the light. So a switch loop incorporates the switch leg
        They say I shot a man named Gray and took his wife to Italy
        She inherited a million bucks and when she died it came to me
        I can't help it if I'm lucky
        Comment
          #5
          You have a switch loop if you bring the hot to the lighting junction box before the switch.
          Comment
            #6
            A switch leg is half of a loop. The other half of a loop is the ungrounded installed specifically to power the switch(es).
            Comment
              #7
              Thanks all.
              Comment
                #8
                So the white wire!?
                Comment
                  #9
                  So in this scenario. Power(12/2) to the switch and you would need 12/3 up to a box between lights. 2 switch legs(a & b) and one for power. Correct?
                  Comment
                    #10
                    Yes if you have two switches then a 3 wire cable (Sa, Sb, N) up to the ceiling is what you would need.
                    Rob
                    All responses based on the 2017 NEC unless otherwise noted
                    Comment
                      #11
                      Sorry!! In this instance, 3 switched hots and a neutral. 12/4!
                      Comment
                        #12
                        Yes.
                        Rob
                        Comment
                        Working...
                        X
