Announcement
Collapse
No announcement yet.
MC Cable Wiring
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    MC Cable Wiring
    If separate neutrals are required and wiring a job in MC cable are you better off using a separate 12/2 for each receptacle circuit or a multiple neutral MC cable? I would think multiple neutral cable would save a lot on qty. of cable although.
    #2
    It also multiplies the number of joints you have to make in every box. In my opinion, 12/2 costs less to use, especially with labor in the equation.
    t may even cost less per foot per circuit in materials alone.
    Master Electrician
    Electrical Contractor
    Richmond, VA
    Comment
      #3
      We would use a 12/2 for each circuit.
      Rob
      All responses based on the 2017 NEC unless otherwise noted
      Comment
        #4
        Why instead of multiple neutral MC?
        Comment
          #5
          It's just easier to pull 12/2 instead of 12/4/4 and with 12/4/4 you have to somehow carry through the other 3 circuits which can lead to wiring errors. IMO it's just not worth it unless your plan is run the 12/4/4 to a big homerun box in the ceiling and then distribute from there. To run that out to a receptacle or switch box just isn't a good plan.
          Rob
          Comment
            #6
            Thank you.
            Comment
            Working...
            X
