Announcement
Collapse
No announcement yet.
Damper Connections
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Damper Connections
    I've always noticed almost all dampers are shown on electrical drawings with a J-Box symbol. They really never require a j-box though. You wired in/out of the actuator.
    #2
    The dampers usually come with an integral box. Not sure why they would indicate a JB on the drawings when you typically do not need another box but you're correct they're almost always drawn that way.
    Rob
    All responses based on the 2017 NEC unless otherwise noted
    Comment
      #3
      Like this.
      https://www.grainger.com/product/DAY...re-Smoke-3HGK5
      Comment
        #4
        Pretty common to see a hardwired appliance or motor indicated as a j-box on drawings.
        [COLOR="Blue"]Brought to you by Carl's Jr.[/COLOR]
        Comment
          #5
          Yep...and a lot of times the dampers, VAV's, unit heaters, etc are in EMT runs due to distance or they are on circuits with different voltages....so J-box and whip is common
          Comment
            #6
            not really true for vav and dampers ...many time 8-10 on same circuit.
            Comment
              #7
              I believe that what he's saying is that if you had the branch circuit run in EMT you wouldn't pipe directly into the damper box you would use a junction box with a whip at each. For MC cable it's more likely to just go directly into the damper junction box.
              Rob
              Comment
                #8
                yes I agree for pipe
                Comment
                  #9
                  I assumed that your spec limits use of MC to fixture/equipment whips and does not allow MC to be run wild like romex throughout a commercial space.
                  Comment
                    #10
                    Not the case. MC is allowed often for all branch wiring in concealed locations of small single phase motors, wiring devices, lighting etc.
                    Comment
                    Working...
                    X
