Hello, I have a problem!
1- What is application of this circuit? What does it do?
2- Simulate this circuit in a simulator software and by determine correct values for resistors, show heat losses (H) is nearly constant.
3- Calculate H analytically (manually) (voltage division) and compare with part 2 in a software.
Hint:
(Comparator)
4- By proper ratio selection for resistors, show sensitivity of heat losses (H) with respect to thermal resistance (Rt) is almost zero.
Hint:
