I have a 110V receptacle on my equipment that will derive its power from a separate source than the equipment. If the disconnect on the equipment is switched to the off position, the receptacle will still be live.
It is my understanding of NFPA79 that I should use yellow wire to wire the receptacle. Would this yellow wire be for the Line and the Neutral going to the receptacle, or yellow just for the Line?
