kevin458
- Bloomington,MN,USA
The IEC breakers have a limit on the length of cable that they can protect. This depends on the impedance of the cable plus the impedance of the ground path, called ground fault loop impedance (Zs). So in IEC the maximum cable length is determined by the values of Zs and Voltage drop. Do in NEC also the maximum cable length is determined by Voltage drop and Zs, or is it only determined by Voltage drop? Thanks
