OCPD/Feeder Calc 3P
Cletis
OH
Sorry, but this is a continuation from another thread. I was very rushed and posted the wrong info. Trying to size feeders and OCPD to a 3 phase sub panel to power these 2 machines. Here is correct info below
Machine 1 10,400VA (Actual Draw peak is 46amps/39amps)
Machine 2 10,400VA (Actual Draw same as above) Both 208V Single Phase
Phase A 10,400VA
Phase B 5,200VA
Phase C 5,200VA
Looking for below
Min Size Feeder
Min Size OCPD
Smart $
Esteemed Member
Ohio
As I recall in the other thread you had said nameplate values were 50A and 55A. Now you're saying 50A each.
Your A-phase VA is correct, but you can't divide by 2 where there isn't matching current from other phase. Currents are 86.6A, 50A, and 50A respectively.
Assuming neither is a continuous load, you're looking at #6CU/#4AL and 90A OCPD.
augie47
Tennessee
Using the VA the load is 50 amps which, according to my calculator, would give you a 87 amp load on the shared phase. Obviously, using your "amps" the load would be less.
Cletis
OH
Excuse the mess before. I was very hasty in posting the info, since then I sorted it all out and this is correct info.
Yes, would you mind posting your math on 86.6, 50, 50? I have a #1 Al 4 wire off a 3 pole 100 for 1 SET of machines, it's the other identical set we may be limited to a 90 3 pole off a #2 Al potentially I'm concerned about. 86.6A on a 90 is cutting it pretty darn close for me but with the lower actual readings of 46/39 and 214V at panel i'm thinking it may run a few amps less in reality. They are currently running on a number #8 Cu on 50 amp 2 pole breakers and they are running fine for years he said off those so
augie47
Tennessee
Been years since I'v done the math... I cheat & use a program that does it for me :)
As for the load, I appreciate your concern and would probably feel the same but keep in mind
(a) it's been running on a 50 amp breaker, (b) Code is "minimum" requirement but is supposedly safe. For comforts sake you might monitor the actual load for a short while.
It appears you might see some low numbers.
Smart $
Esteemed Member
Ohio
The 50's are easy. There is no math involved.
The 86.6 is just 50A times square root of 3.
Cletis
OH
Wanna Share your program ?
How would loads change per phase if I land the 2-2pole breakers on 1(A),3(B),5(C),7(A) v.s. 1(A),3(B) and 2(A),4(B) (Phase C nothing)??
