40 amp dryer circuit
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Other than the fact that they ay have used an old range circuit I have no idea why it would be on a 40 amp circuit. 30 amp is what is required.
Coppersmith
Tampa, FL, USA
I've also seen 60 amps range circuits and other circuits that are incorrectly protected. If I'm doing a panel change, I automatically correct these situations. Otherwise, I strongly suggest to the HO that they change them to avoid a fire. Just the other day I came across a 20 amp water heater (with #12 wires) on a 30 amp breaker.
hbiss
Hawthorne, New York NEC: 2014
EC
Back in the day large 36" electric ranges with two ovens were popular. My parents had one and the 50A circuit and receptacle is still there. I've since converted to gas.
-Hal
mbrooke
Batteries Included
United States
Technician
Actually, in the 50s, there was a dryer that took a 50amp circuit. The concept did not last long, but I think it was to mimic a gas dryer in speed. Someone older may remember it.
Coppersmith
Tampa, FL, USA
Not to code, but if you ask me thats a none issue. Common practice in Canada.
:? I don't see how you can say protecting a 20 amp circuit with a 30 amp breaker is a non-issue. Don't we discuss putting the proper sized breaker on circuits all the time.
mbrooke
Batteries Included
United States
Technician
The heater isn't a receptacle- more load can not be added to the circuit.
