RD12
New member
- Tulsa, OK USA
I'm a bit confused reading through some textbook material regarding under/over voltage when dealing with A/C induction motors. What I believe I understand is this:
---A given motor operating at a lower voltage than rated on the nameplate will cause the motor to overheat and burn up from the high amps passing through it.
---A given motor that is operating under a heavier load than rated on the nameplate (in Horsepower) will cause the motor to overheat and burn up from the high amps passing through it.
So my question is this.......If an induction motor has a given impedance/resistance (in ohms) then wouldn't it burn up from a higher voltage than rated on the nameplate as well? (Due to I/R)
Looking for some guidance!
