Announcement
Collapse
No announcement yet.
3 Phase Balance Delta System - 30 Degree Phase Shift for Apparent Power
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Click image for larger version
Name:	Three Phase Power Calculation.JPG
ID:	2388665Click image for larger version
Name:	Three Phase Power Answer.jpg
ID:	2388666Click image for larger version
    With Problem 111
    I solved it by using the following formula
    S = √3∠-30*VL*IL* = √3∠-30 * (12.5∠0kV) * (70∠20) = 1515.54∠-10.
    But in the other problem posted, why isn't there a 30 Degree Phase shift as well.
    They are both 3 Phase Balanced Delta Loads.
    #2
    Originally posted by BatmanisWatching1987 View Post
    [ATTACH=CONFIG]22427[/ATTACH][ATTACH=CONFIG]22428[/ATTACH][ATTACH=CONFIG]22429[/ATTACH]
    With Problem 111
    Where is the rest of the work?
    It matters if you are using I_phase vs. I_line.
    V_L in the problem is using V_LL voltage (perhaps the L they use is for "load"?). Maybe the I_L is I_phase.
    BB+/BB=?
    Comment
      #3
      With Problem 111
      I am pretty much sure this question was asked in a different thread and answered. When calculating 3 phase power (reactive, real or apparent) forget about the 30 degree shift between phase and line voltage/current. Only angle that matters is your load impedance angle which in this case is negative arc cos(0.85) = -31.8 = θ
      P=3XVφXIφXcos(θ)
      Q=3XVφXIφXsin(θ)
      S=3XVφXIφ
      "Because it's there!"
      George Mallory
      Comment
        #4
        With Problem 111
        This isn't at all helpful, but I'm so glad that I don't have to study for the Power PE Exam again! I was doing what you're doing this time last year. Good luck!
        Comment
          #5
          Here is my solution for Problem 111
Name:	Solution to Problem 111 Apparent Power.JPG
          Comment
          Working...
          X
