Announcement
Collapse
No announcement yet.
Basic theory/formula's
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Okay, I remember the E, I, and R formula according to Ohm's law, but can some one remind me of the Watt formula? I know E x I = W, but how do I figure resistance from 100 watts and 120 volts?
    #2
    Re: Basic theory/formula's
    PIE
    Comment
      #3
      Don't forget that you can substitute from E=IR to P=IE and vice-versa. An example would be to substitute for E, P=I(IR) becomes P=I^2R.
      Charlie Eldridge, Indianapolis, Utility Power Guy[COLOR=red][/COLOR]
      Comment
        #4
        The logical approach by only using one formula is...120 times 120 = 14400 divided by 100 = 144 ohms.
        Comment
          #5
          I find that an Ohm's law equation can always be solved by remembering one rule:
          I x R = E can be changed to
          E / R = I or
          E / I = R
          It might be clearer to use numbers:
          2 X 3 = 6 can be changed to
          6 / 3 = 2 or
          6 / 2 = 3
          Given any two variables the third can always be deduced. I also think of this as being able to "unmultiply" something by dividing it in the opposite direction. :cool:
          100w / 120v = .833333A and you need resistance
          that's E / I = R or 120v / .833333A = 144ohms
          [ May 09, 2003, 03:54 PM: Message edited by: physis ]
          Sam, San Francisco Bay Area
          Comment
            #6
            Watts = volts x amperes, P = E x I. however, this is only where you have a purely resistive load or unity power factor, no inductive loads. Where inductive loads are supplied, watts = volts x amperes x power factor, P = E x I x PF.
            Comment
              #7
              Comment
                #8
                Get yourself an Ugly's book, for under $20, it is a handy reference book full of electrical formulas, and other useful info.
                Comment
                  #9
                  DOCTOR WATTS pocket guide is pretty good too by Mark Shapiro.
                  Bryan P. Holland, MCP
                  NEMA - Codes & Standards
                  Comment
                  Working...
                  X
