Announcement
Collapse
No announcement yet.
Wire Size
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Wire Size
    Have 120/208 3P 4W 100A being fed from 3P 40A breaker. One drawing asking for 4#6 & another drawing asking for 4#8’s. Conductors should be sized off 40A breakers, correct? So #8’s ok.
    #2
    As long as there are no adjustments needed that reduce #8 to less than 40 amps, yes #8 is minimum size needed here per NEC.
    I live for today, I'm just a day behind.
    Comment
      #3
      Long distance may merit #6 but as kwired stated the #8 is compliant. I would definitely ask the engineer and get this corrected on the drawings
      They say I shot a man named Gray and took his wife to Italy
      She inherited a million bucks and when she died it came to me
      I can't help it if I'm lucky
      Comment
        #4
        It might also be a future consideration; ie 40 A now with a possibility of bumping to 60A later without having to pull new conductors.
        __________________________________________________ ____________________________
        Many people are shocked when they discover I am not a good electrician...
        I'm in California, ergo I am still stuck on the 2014 NEC... We'll get around to the 2017 code in around 2021.
        Comment
          #5
          Why not install the 60 amp breaker now if that is the case? Especially if is three pole or a 277/480 volt breaker. Your double pole plug on breakers 60 amp and below are usually pretty inexpensive and there is a possibility you put in a 40 now, though I'd still normally put in the 60 now if that was the reason.
          Comment
            #6
            Either conductor size is code compliant I would use the #8 unless there is a voltage drop concern.
            Rob
            All responses based on the 2017 NEC unless otherwise noted
            Comment
            Working...
            X
