Announcement
Collapse
No announcement yet.
RV Park 240v vs 208
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    RV Park 240v vs 208
    Do RVs actually use any L-L voltages internally?
    Im working on an RV park and there are several that are under construction in my area. I was given some drawings to use as reference and I noticed that the reference designs go out of their way to provide 240v to the RV sites for the 50A receptacles. The reference designs either show a 120/240-1 service that results in a massive service, (or) show a 480v service with single phase transformers.
    I know that Shore Power for boats do require 240v because they utilize control transformers internally and if 208v is brought to a boat it could become an issue.
    However, from what I can tell, all the loads within an RV are actually 120v. Therefore, a 120/208-3 source would really have no impact. Im sure there is some exception where an RV may have a L-L load however chances are that could likely run off of 208v like most other loads.
    #2
    I've never seen an RV with 2-pole loads, and I've worked on several, old and new.
    Comment
      #3
      If you read article 551 you will see that there are rec vehicles that use 120/240v 50 amp or 120/208 50 amp. Maybe they use electric heat and a/c....
      They say I shot a man named Gray and took his wife to Italy
      She inherited a million bucks and when she died it came to me
      I can't help it if I'm lucky
      Comment
        #4
        551.72(C)
        I believe that is saying you must feed a 50-amp 125/250V receptacle with 120/240 not 120/208. Same as 555.19(A)(3), the informational note is note worthy.
        Comment
          #5
          From what I know, Rvs that need a 30A only have one A/C unit and the 50A ones have two A/C units. But I don't think the two unit ones are L-L just two 120V circuits. You run a 2-pole (L-L) 240V to split the 120V loads.
          [COLOR=navy]If you aim at nothing, you will hit it every time![/COLOR]
          Comment
            #6
            I believe Bill is correct but not sure when it comes to clothes dryers that may be installed.
            Comment
              #7
              Be aware of EV charging, which tolerates both but usually is faster at 240V.
              Comment
                #8
                I work on an annual event where we power 50 or so large RVs for a week from a couple towable diesel generators. All 3 phase 120/208 generators and distribution and 50 amp 4 wire connections for the RVs. I have never seen one of these rigs with any L-L loads.
                Comment
                  #9
                  And a dryer works perfectly on 208v, with the element at 75% of 240v power.
                  Master Electrician
                  Electrical Contractor
                  Richmond, VA
                  Comment
                    #10
                    We're also working on a design for an RV park. After talking it over with a tech from a large RV service center it was determined that even the biggest RV's with dual 50 amp cords still use only L-N loads.
                    At this point, we are figuring on two services at 208/120v 3 phase.
                    Comment
                      #11
                      If Billy Idol is on your playlist go reevaluate your life.
                      Comment
                        #12
                        Comment
                          #13
                          Multiquote is not working after the update.
                          Comment
                            #14
                            See 551.40(A). Any Line to Line loads or equipment installed in an RV must have a voltage rating of 208-230 volts.
                            So 208V will work with any L-L RV load.
                            Comment
                            Working...
                            X
