Announcement
Collapse
No announcement yet.
consensus on replacing affected cables
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    If you replace elec. equipment such as pump/fan motors etc., do you guys typically demo the existing cables and install new cables or just re-use existing cables?
    What is the preference for something like this typically?
    thanks
    #2
    thanks
    I don't know what the standard practice is there. I'd test and and physically inspect it. If OK, I'd reuse it.
    Comment
      #3
      thanks
      If everything looks and tests good, use it.
      Tom
      TBLO
      Comment
        #4
        I would check the age/type of the existing cables when evaluating whether or not to reuse it.
        Rob
        All responses based on the 2017 NEC unless otherwise noted
        Comment
          #5
          I think you need to look at replacements in general on a case by case basis, but if the equipment is worn out, I'd be inclined to seriously consider replacing the conductors and raceways.
          Bob
          Comment
          Working...
          X
