Announcement
Collapse
No announcement yet.
Feeder Size
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Feeder Size
    So have a 150A breaker feeding three 200A panels. It’s one feeder of 4 #1/0’s and #6. Two of the panels are gutter tapped and total feeder run length is 150’ Each panel have total connected load of 4,800. #1/0 good for 150A. Is this the right feeder size for this situation?
    #2
    Sounds like you have an issue with the tap rule.
    Comment
      #3
      If each panel only has a load of 4,800 va or watts then 150 amp (1/0 copper) should be fine. What are you having a problem with on the install?
      They say I shot a man named Gray and took his wife to Italy
      She inherited a million bucks and when she died it came to me
      I can't help it if I'm lucky
      Comment
        #4
        I assume the panels have a main breaker...Yes?
        Comment
          #5
          I don't think they need one
          Ethan Brush - East West Electric. NY, WA. MA
          "You can't generalize"
          Comment
            #6
            It depends on what size the tap conductor is... If they are 1/0 then it is not really a tap..
            Comment
              #7
              Sounds like a splice not a tap so no main OCPD required at each of the three panels.
              Rob
              All responses based on the 2017 NEC unless otherwise noted
              Comment
                #8
                Yes
                Comment
                  #9
                  Yes, splice or tap.
                  Comment
                    #10
                    Why would the size matter as to whether it's a splice or tap?
                    Comment
                      #11
                      See 240.2 - Definition of "Tap Conductors"
                      Comment
                        #12
                        ty
                        Comment
                        Working...
                        X
