Announcement
Collapse
No announcement yet.
240V 3P Delta to 208V 3P Wye
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    I have a customer that has a piece of equipment that runs on 208V 3P, but the power to the building is 240V 3P with a Delta High Leg
    Is there a good way to convert the 240V high leg to 208V 3P Wye?
    The equipment only pulls 20A, so I was thinking of a small buck boost XFMR.
    #2
    Are you sure that the machine cannot handle 240V? It would be unusual if that were the case. Investigate that thoroughly before buying anything.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
    I'm in California, ergo I am still stuck on the 2014 NEC... We'll get around to the 2017 code in around 2021.
    Comment
      #3
      Thank you. I didn't really think about that, but that sounds right. I'll ask the customer to check the nameplate.
      Comment
      Working...
      X
