Announcement
Collapse
No announcement yet.
Disconnection time 120 volts vs 150 volts
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Is there any real danger in using a 0.8 seconds as disconnection time for 150 volts line to ground? Or would a sweet spot at 0.7 seconds work? Call me cheap but I don't want to use 0.4 seconds unless I really have to.
    #2
    1 second will work from here.
    What are you removing power from? Is there a current level and time at 150 volts?
    I know it’s all above my pay scale, but I’m curious what you are attempting to do.
    Tom
    TBLO
    Comment
      #3
      I like your thinking
      15, 20 and 30 amp branch circuits. At 120 volts to ground the breaker is required to trip at 0.8 seconds or under. At 150 volts to ground 0.4 seconds or under. Sounds like a lot simply going from single phase to three phase.
      And don't sell yourself short
      Comment
        #4
        The time is dependent on the resistance (length) of the 14, 12 and #10 cu.
        Comment
          #5
          I can recall an old farmhouse way out , with a barn wired off of it, to yet another barn in the back 40....
          One could arc something all day long, w/out the ocpd opening @ the main house
          ~RJ~
          Comment
            #6
            A LONG time ago I did an absolute Minimum with max VD for a short time project. 240v 3Ph, IIRC. Under a bolted fault that developed at the far end, the voltage would drop out the control but never blew a 60 amp fuse.
            Tom
            TBLO
            Comment
              #7
              If you know the short circuit current at 150V, the short circuit rating constant ( K ) of the type of cable, obtainable from cable manufacturers, then you can calculate the area of cable suitable for your requirement. The formula is . Area= (I/K)*√time. Note:The formula applicable upto 5 seconds only.
              Comment
                #8
                Ah! The area as expressed in formula in my previous post is in Sq.mm.
                Comment
                  #9
                  Sahib, this is what I'm looking for! I have the mm2. Is this enough?
                  Comment
                    #10
                    ~RJ~
                    Indeed what I'm trying to avoid. 60 standing volts on the grounding system might be an issue to anyone with low skin conductivity and standing in mud.
                    Comment
                      #11
                      Yup! You see what I'm trying to avoid (trying to accomplish)
                      So how do I go about the math?
                      Comment
                        #12
                        Perhaps this would help:
                        http://www.electrical-installation.o...ircuit_current
                        http://www.electrical-installation.o...uit_conditions
                        Comment
                          #13
                          Thank you- I will look at your links and ask questions after I eat.
                          Comment
                            #14
                            Enough for what?
                            Comment
                              #15
                              Enough for what?
                              For the area of the cable.
                              Do you do loop impedance in your Country?
                              Comment
                              Working...
                              X
