Announcement
Collapse
No announcement yet.
conduit fill
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    conduit fill
    Hi,
    what size EMT for (4) 3/0 THHN, + 1/0 EQG, Cu ????
    thank you
    #2
    What do YOU come up with?
    Comment
      #3
      I know, I know! Pick me, pick me!
      Master Electrician
      Electrical Contractor
      Richmond, VA
      Comment
        #4
        Use Tables 4 and 5 in Chapter 9
        Chapter 5 gives you the area of the conductors-- so 3/0 THHN is .2679 sq. in. Now multiply by how many conductors you have and then do the same for 1/0.
        Now add them together and go to Table 4 -- the first table is for EMT and look under the col. for more than 2 wires and find a conduit size that is at least as large as your calculation
        They say I shot a man named Gray and took his wife to Italy
        She inherited a million bucks and when she died it came to me
        I can't help it if I'm lucky
        Comment
          #5
          Bigger than 3/4"
          Roger
          Comment
            #6
            Originally posted by roger View Post
            Bigger than 3/4"
            Roger
            Yep, I think 1" would be better.
            Comment
              #7
              It will fit in 4”
              Comment
                #8
                Originally posted by jusme123 View Post
                It will fit in 4”
                I'n guessing he means 'minimum' size.
                Master Electrician
                Richmond, VA
                Comment
                  #9
                  Hint: It's the same size whether you pull in the 1/0 EGC or not.
                  Not sure why you'd need a 1/0 EGC, though.
                  Comment
                    #10
                    Or any EGC, for that matter.
                    Master Electrician
                    Richmond, VA
                    Comment
                      #11
                      Could be specs, but still.... 1/0 EGC for 3/0's?
                      Sounds like a test question to me.
                      Comment
                        #12
                        10 inch
                        Bob
                        Comment
                          #13
                          You can skip the calculation by looking in Table C.1 in Annex C.
                          Rob
                          All responses based on the 2017 NEC unless otherwise noted
                          Comment
                            #14
                            Another option, there is also this great thing called Google and the internet. Open your computing terminal, and type in "raceway fill calaculator" and I bet you a Reuben you will have multiple choices.
                            Ethan Brush - East West Electric. NY, WA. MA
                            "You can't generalize"
                            Comment
                              #15
                              annex C is only if all the conductors are the same size
                              Comment
                              Working...
                              X
