Announcement
Collapse
No announcement yet.
Absorbed current
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Absorbed current
    Can anyone explain the term Absorbed current?
    #2
    Re: Absorbed current
    Absorbed current as opposed to impervious current ?
    WOC
    Comment
      #3
      I did a quick search, and found the term used in power electronics applications (one example is electron microscopy) and in motor applications. But I did not find a definition in either application. It might help if you told us how you came across the term (i.e., in what context).
      Charles E. Beck, P.E., Seattle
      Comments based on 2017 NEC unless otherwise noted.
      Comment
        #4
        Current absorption is a dielectric property of a substance or material that effectively allows stored energy to be recovered.
        Applications are in common equipment such as capacitors, X-ray machines, and electronic circuitry.
        Bryan P. Holland, MCP
        NEMA - Codes & Standards
        Comment
          #5
          Absorbtion current in power cables is the amount of current that flows and is absorbed by the dielectric insulation, that is caused by polarization. A similar current occurs in the insulation of motor windings when stressed with DC voltage.
          Comment
            #6
            I guess the simplest way to explain the action of absorbed current is that it's similar to a capacitor where the current can be recovered.
            Comment
            Working...
            X
