I have 2 AFCI's that serve three upstairs bedrooms. The AFCI's will test fine at the panel, and will stay switched in when reset (I have checked voltage at the receptacles, looks good). The problem occurs when I plug in a lamp or other device into any of the bedroom receptacles. Each AFCI will trip (independant of one another) when a device is plugged into a receptacle on the circuit. A digital clock will not trip wither AFCI (perhaps not enough draw?). I switched out AFCI's and still the same problem. I wired my kitchen plugs into the AFCI's and they work fine, no trip when plugging in any device. Wondering if the problem could be shared neutral between both bedroom receptacle circuits? To be clear, the AFCI's serving the bedrooms will stay switched in until a device is plugged into any bedroom outlet.
Thanks in advance for any advice.
