What is the pump being used for? Does it need to be running all the time?Guys, a client bought a 3000 gpm pump without asking. now, they don't need that...can we suggest to use a VFD to automatically reduce the speed so that it would not pump out 3000 gpm but less which is required?
As steve said, you didn't give us much.Guys, a client bought a 3000 gpm pump without asking. now, they don't need that...can we suggest to use a VFD to automatically reduce the speed so that it would not pump out 3000 gpm but less which is required?
[/QUOTE]As was mentioned earlier, a throttle valve or a valve and impeller trim works pretty good and may be a lot easier/cost effective than installing a VFD.
Well, I was thinking life cycle cost as opposed to installation cost.bes said:A throttle valve may well be cheaper for initial supply and installation than a VFD.
But...
the VFD would continue to save on energy costs over its life.
Let's examine your statement from lifecycle cost standpoint.
Application is an irrigation system, 4 hours/day, 3 months a year, power is $0.1 kwh. Money costs 8%.
I respectfully disagree on several points.1. A 125hp VFD with isolation transformer is at best 90% efficient and costs $100K installed. Hydraulic efficiency drops from 72% to 68%
On efficiency:
First, why assume a need for an isolation transformer?
Even if you do, it ought to have an efficiency of no worse than 98%. The VSD would typically be 97% or better. So combined 95% at worst.
We routinely have to commit to efficiency figures to within 0.1% at the tender stage. Getting them wrong would incur iniquitous financial penalties. B
On costs:
If we could get anywhere near $100k for a 100 kW VSD installed we'd be quids in. We can't. Our last installation of drive and cabling was for a 225 kW drive, installation, and cabling.At the prevailing exchange tare it would have been around $60k
Perhaps I should be. But I'm not.You're in the vfd business, they are all cool, and I suspect you are a bit preselected toward vfds for all solutions.
Above all, integrity and honesty matters most.
If I think a VSD isn't the way to go I'd say so even if it means potential loss of business.
2. The existing pump (already paid for) with an impeller trim puts the pump within 5% of the needed capacity and head. A manual throttle valve does the rest. Trim and valve installed cost is $10K. Hydraulic efficiency drops from 72% to 65%. Additional 5% dropped across the valve.
3. A new 100hp motor with pump with new motor costs $30k. But whoops, it still isn't right - needs an impeller trim to get it right (yep, pretty common) Hydraulic efficiency is 75%.
Q: What is the payback time for options 1 or 3 over option 2.
Never for option 1??. Maybe never for option 3??
You are right we don't know the application. Adding to what I said earlier, if it is a low hour/year operation, or is the pump curve is not far from the application, the existing pump/motor may well have the lowest lifecycle cost.
You're in the vfd business, they are all cool, and I suspect you are a bit preselected toward vfds for all solutions. But they are not necessarily the most cost effective - and, I knew you knew that
cf
You should really get out more often.:smile:
- A 125HP drive with filter is $100K? Try <$10K plus installation DIFFERENCE compared to the regular starter $3K.
- Efficiency 90%? try 96% -2% for the filter IF needed.
- Throttling power loss? 30-65% depend on where you may be on the operating curve.
- The pump curve at reduced speeds will be different and so will the optimum operating point and efficiencies. Impeller trim may drive the whole efficiency in the other direction compared to reduced speeds.
- Cost of valve? (You don't even know the size and if it is a control valve it quadruples the pricing as a minimum.)
- Not only the reduced energy cost but the reduced maintenance cost and the prolonged life of the motor and pump should be taken in consideration for lifetime cost analysis.
There is a vast amount of energy to be saved in controlled fluid and gas flow applications by removing the control valves, dampers and replacing them with ASD's.
IMHO, it depends on the specific application.
If a process is properly designed, and the pumpwork is not of the variable-flow type, you won't need VSD's (ASD's).
Do you believe that VSD's (ASD's) are one-cure-for-all solutions?
And didn't we hear more installations having problems with power quality, harmonics, overheating, etc. all related to power electronics? I smell snake oil!
There is.There is a vast amount of energy to be saved in controlled fluid and gas flow applications by removing the control valves, dampers and replacing them with ASD's.
And I respectfully suggest your numbers are better than mine:smile: I'm surprised my guesses were within 50%.---I respectfully disagree on several points.
On efficiency:
Even if you do, it ought to have an efficiency of no worse than 98%. The VSD would typically be 97% or better. So combined 95% at worst. ---
On costs:
If we could get anywhere near $100k for a 100 kW VSD installed we'd be quids in. We can't. Our last installation of drive and cabling was for a 225 kW drive, installation, and cabling.At the prevailing exchange tare it would have been around $60k ---.
I think my premise that a low hour/year machine has a real hard time paying off an efficiency investment is still true.
And I knew you thought that.--- Above all, integrity and honesty matters most.
Where I am headed is typfied by wer's statement:
For some it all too easy to say, "Install a VFD - there are huge cost savings from increased efficiency". Yes, I know that is not what you are saying.
My recomendation here is, "Do your home work first - don't guess. Maybe a VFD is a good answer, maybe the answer is a simple impeller trim"
cf
I don't believe anyone with experience in the field of variable speed drives would believe so. Certainly weressl didn't.Do you believe that VSD's (ASD's) are one-cure-for-all solutions?
I'd rather lose a contract than lose a customer.Above all, integrity and honesty matters most.
Variable speed drives are one application of power electronics. Non-linear loads from whatever source result in harmonics.And didn't we hear more installations having problems with power quality, harmonics, overheating, etc. all related to power electronics? I smell snake oil!
That's the way I see it. Pump manufacturers have been designing pumps for 150? years, and do pretty well at it.IMHO, it depends on the specific application. If a process is properly designed, and the pumpwork is not of the variable-flow type, you won't need VSD's (ASD's).---!
Yes. Wasn't there a thread a bit back talking about how all of the refrigeration vfd controls in a large store were generally turned off cause they couldn't get them to work right - or they would break and the repair costs weren't worth it? Makes one wonder about the life cycle costs.--- And didn't we hear more installations having problems with power quality, harmonics, overheating, etc. all related to power electronics? ---
I don't think so. Like everything else, one must do the engineering to get a cost effective, low maintenance, system that meets the customer's spec.--- I smell snake oil!
I don't know about that. Wer says he can install a 125hp drive for less than $10K. :roll: That would just about make any control valve, regardless of the hours/year of use, a poor choice.I don't believe anyone with experience in the field of variable speed drives would believe so. Certainly weressl didn't.
---Yot only the reduced energy cost but the reduced maintenance cost and the prolonged life of the motor and pump should be taken in consideration for lifetime cost analysis.
cf
