Announcement
Collapse
No announcement yet.
Load Calc with Shower Steam Unit
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
    197A[/COLOR]
    #2
    Check it with MH's residential load calculator online. Once at the link scroll down to residential load calculator.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
    Comment
      #3
      Try this software program. http://www.theelectricalguru.com/dwellingcalc.xls
      You missed disposal, trash compactor, ice maker, others.
      Comment
        #4
        Maybe the house doesn't have them. Outside the city where you have septic fields you cannot have a disposal around here. TC and IM are not on everyones wish list.
        Comment
          #5
          These are plain old folks around here. Nothing fancy.
          Comment
            #6
            http://forums.mikeholt.com/showthread.php?t=127901
            Check that thread out from yesterday, Charlie b spelled it out pretty well. Add your steam shower separately.
            It appears your using the nameplate value for a lot of your values, I would be careful doing that. At least use 1500VA for your microwave & 5000 VA for your dryer & 1500VA for your dishwasher. All those appliances are easily replaceable.
            Just my opinion.
            Comment
              #7
              Heres a PDF of my load calculation I typically use for residential.
              The bottom may be the most confusing thing, but basically you subtract 10KW from your loads, then take the remainder at 40%.
              Comment
                #8
                That is using the optional calculation. I don't think you can take the range at 8KW when using the optional calculation -- needs to be nameplate value. I think the OP will get a much smaller load calculation with the Optional Calculation since a 40% factor applies to most items. With the standard calculation, it is going in at 100%, or 75% if you can happen to find 3 other appliances to use for the 4 or more demand.
                Mark
                Kent, WA
                Comment
                  #9
                  the optional load calculation does make you use name plate value for the range, however your wrong about the 75% demand factor. See example D2(a), page 1344 if you have the handbook.
                  The demand factor for the optional calculation is the calculated VA - 10KW + REMAINDER @ 40%
                  Comment
                    #10
                    The EE I use sometimes e-mailed back and said that I needed to add the steam unit in the second half with my A/C's which puts my calc at 245A-ish.
                    He also said that the original calc at 197 would make them (his firm) go ahead and call for a 400A service. CYA thing for them.
                    Comment
                      #11
                      Just my opinion.
                      I had looked at that. I still wasn't sure how to handle the Steam Unit.
                      Comment
                        #12
                        The stove was 7.5Kw @240V. I just left the 8Kw.
                        Comment
                          #13
                          The 75% factor I was mentioning is for the STANDARD calculation when you have 4 or more appliances fastened in place [220.53].
                          Mark
                          Kent, WA
                          Comment
                          Working...
                          X
