Announcement
Collapse
No announcement yet.
MBC for 18 4ft. 4 lamp dual ballasts T8's
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Would you see any probem with pulling one 20 amp MBC for 18, 4 lamp, 4 ft. dual electronic ballast fixture, and switching the ballast separetely with two switches. ?
    #2
    sorry, voltage is 120
    Comment
      #3
      I think you need to check your ballast info
      Comment
        #4
        On a 208y/120 system? Sounds like around 8A on 3 ungrounded conductors.
        Comment
          #5
          This is a single phase panel I will be coming out of 120/208, also did not have the fixtures yet so did not ballast amps.
          Comment
            #6
            I was thinking(maybe not too clearly lately), that although you should be fine, you need to have ballast information to verify.
            Comment
              #7
              Are you talking about switching just 2 of the 4 lamps in a single fixture, or do you mean switching 9 & 9 fixtures? What is MBC-? branch circuit?
              [COLOR=navy]If you aim at nothing, you will hit it every time![/COLOR]
              Comment
                #8
                As others have said, you really do need the ballast info to be certain.
                That said, I went to Grainger - a 4-lamp, 120v ballast is rated at .91A each....
                .91 x 18 fixtures = 16.38A total....so putting these on 2 ckts should be fine.
                [input watts per ballast was 112w....arithmetic still works just fine].
                Comment
                  #9
                  Im talking about switching just 2 of the 4 lamps in a single fixture.
                  MBC - multiwire branch circuit
                  Comment
                    #10
                    That's kinda what I thought but wasn't sure.
                    Thought multiwire too, but used to seeing MWBC.
                    BTW, I don't see a problem with what you described.
                    Comment
                      #11
                      Thanks, sorry bout the confuson , I left the W out
                      Comment
                      Working...
                      X
