GFCI Trips on Pond Fountain
tlcook
New member
Timbuktu
I have a pond fountain with 3 submerged lights. The pump is controlled by a mechanical timer and the light is controlled by a photo sensor. Both the pump and the lights are connected to a single blank face GFCI. The pump runs fine until the light comes on in the evening, and then the GFCI trips a few minutes later. The light also works fine without the pump. Only when both are on does the GFI trip. Tried a new GFCI, but nothing changed. Anyone ever encounter anything like this before?
George Stolz
Windsor, CO NEC: 2017
Service Manager
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
