Announcement
Collapse
No announcement yet.
277V Step down XFMR
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    277V Step down XFMR
    Hello all,
    Any help on this would be appreciated.
    If I put a 277V step down XFMR to 120V to feed some 120V fixtures (lightolier #7997) on the same circuit with 277V fixtures; will this work with two different voltages feeding back on the same neutral?
    I found this transformer (see attached) that looks like will accomplish this, but all of my colleagues tell me it won't work due to the neutrals.
    Any thoughts?
    Thanks,
    Cliff
    #2
    It appears you have a buck-boost autotransformer. The autotransformer will need an input fuse not greater than 1.8A per 450.4(A)Exc. Can't tell if its supplied with the transformer from the cuts.
    But I don't see any reason that it wouldn't work together with other fixtures on the same 277V branch circuit.
    Comment
      #3
      That's a standard autotransformer setup. It will work.
      Bob Wilson
      Comment
      Working...
      X
