CONTROL FREQ
- OHIO
Been workin a lot of O.T., didn't go straight to bed for a change. Thought I might ask a simple one for you fellas (and gals) that know the book verbatim. Long story short... we rewired a huge building from scratch thanks to "crack-heads" inhabiting and essentially stealing everything copper, brass, aluminum, or anything else commonly sold for "scrap". My small problem arised when an inspector told my boss that the installed GFCI receptacles, will have to be tested once a month. Not a big deal right? Just blow a little sunshine in the general direction of this guy's posterior, and everything will be fine... of course we will push the 'TEST' button once per month:angel:... Not so easy. Now the boss thinks this might be a necessity in ALL of the buildings. I told him of course, that I always was told it is reccomended but I tend to just press the test button whenever I see a GFI... merely out of habit. IS THIS AN ACTUAL RULE NOW? I didn't even bother trying to look it up, but if it is (OR isn't hopefully), I need a code to reference. If you can help me out, I'll do my best to help back sometime.:slaphead::dunce:
