Weep hole in LB?
Robotm
New member
I'll be replacing my electrical panel shortly and the local inspector has told me I need to drill a hole in the LB. I presume this is a weep hole. I was unsure of the exact location, size, number of holes? I was just planning on a single 1/8" hole at the lowest point of the LB before it enters the house. Does this seem logical? I've also been told it needs to be packed with Duct Seal, again, presuming as the the service wire enters the house.
I just wanted to make sure I have everything lined up before the inspection. Thanks!
jumper
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
