danno1202
- Mounds View, Minnesota
I am installing a residential service panel in an outside wall. In order to make the conduit entry as inconspicuous as possible, I want toavoid having an LB on the outside of the house, behind the panel. The meter ison a pedestal some distance from the house, so I?ll be piping it to there. I?dlike to go straight down with the PVC inside the wall, then offset it out atthe very bottom of the wall, going straight into the ground. Can anyone see anyproblem with doing it this way? There?s going to be a deck right there, so Ididn?t want the LB and pipe there. The pull should be just as easy from thepanel vs having the LB on the outside.
