Announcement
Collapse
No announcement yet.
ABB VFD RUN PROBLEM
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    ABB VFD RUN PROBLEM
    [COLOR=#333333]Dear All,[/COLOR]
    [COLOR=#333333][/COLOR]
    [COLOR=#333333]We have this same issue on other Allen Bradley Drives: 1336F-BP400-AN-EN-NCM & 1336F-B200-AN-EN.[/COLOR]
    [COLOR=#333333]Please give valuable suggestions to solve the problem.[/COLOR]
    [COLOR=#333333]With best regards,[/COLOR]
    [COLOR=#333333]Mumtaz Ahmed[/COLOR]
    [COLOR=#333333]AGM- Electrical[/COLOR]
    #2
    Have you tried starting the motor across the line (bypassing the VFD) to confirm that the motor is good?
    Verified the wiring to the motor?
    Does the drive display an error code?
    Comment
      #3
      Sounds like it is being given a run command with a speed reference of zero.
      Bob
      Comment
        #4
        Did amything change, or did this just start happening all of a sudden? Is there a disconnect switch between the drive and the motor that might be open?
        __________________________________________________ ____________________________
        Many people are shocked when they discover I am not a good electrician...
        I'm in California, ergo I am still stuck on the 2014 NEC... We'll get around to the 2017 code in around 2021.
        Comment
          #5
          Green for run? I'm used to red for run, green for off. Are you sure it's getting a run input?
          Comment
            #6
            With limited information, so far that sounds like best possibility.
            I live for today, I'm just a day behind.
            Comment
              #7
              How are the RUN and SPEED commands being sent to the VFD ? Hard wired digital inputs or over network ?
              Comment
                #8
                1336F by the way is an old ALLEN BRADLEY drive, not ABB (Asea Brown Boveri).
                1336F drives were discontinued in 1998, Rockwell had a "last buy" on components for repairing them in back in 2006, and they were officially made obsolete, meaning no more support for them, in 2014. 16 years is a long time for continued support on anything electronic like that, longer than most, but all good things must come to an end some day. Might be time to think about upgrading them to never versions.
                Comment
                Working...
                X
