transfer switch for generator
Electric range is on a 50 amp breaker, what size breaker do I need in the transfer switch? The hot water heater and heat pump are on disconnects, do I still just wire the transfer switch to the breakers as normal?
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I am sorry but this is a diy question AND it is clear you need to get some professional help from a local electrician. Beside that there isn't near enough info here to answer the question.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
You need to be a lot more informative.
Is this a transfer switch/power panel combo?
I don't understand what the heat pump and hot water heater being on disconnects has to do with it either, are the fused disconnects? Are the disconnects fed from the panel you want to put on the transfer switch?
