Current flow???
It would seem to me to be a more acceptable way to installing a portable generator to a house............
to install a small sub panel with critical circuits in it so you are attaching the neutral of the generator to the neutral of the sub panel and the ground of the generator to the ground of the sub panel...
BUT... since the sub panels neutral and ground go back to the main panels bonded neutral block, wouldn't it be the same as tying the generator into the main panel ( generator n+g to panels bonded neutral with no separation)
Is there any difference or benefit to creating two separate blocks in the panel board?? (or bring both neutral and ground from generator to main panel and don't sweat it?)
Wondering. And I think I asked this question 4 or 6 years ago about paralleling the ground and neutral and I think the answer was "do it". correct??
Thank you
Thank you
