I'm going to try to explain my situation I have an out door pool panel feeding two different locations for receptacles. Each location has a metallic two gang outdoor. Box being fed via PVC conduit. Each box has 2 receptacles one constant feed and one switched receptacle. The switched receptacle is to feed a plug in transformer for landscape lighting. So basically I have a splice in the panel because it's only 2 ckts and the piping was done before I got there. When I turn everything on gfci breaker trips so I disconnect the nutreal going to one side of the switched receptacle that has nothing pluged into it at the m moment and it's fine. as soon as I touch it back it trips. My guess is a nutreal leaking somewhere. By the way there are dedicated egcs in each PVC run that are spliced to the box and receptacls as well . How would you go about testing for this with a tester to narrow down further
Sent from my SM-G950U using Tapatalk
