Bad idea. I'm a retired fire captain and have been on two massive house fires where a downstairs bathroom had outlets in the drawer. On one, the homeowners daughter put the curling iron into the drawer with it on and closed the drawer. The other was a house guest who did the same thing.
Not saying it was the drawer outlet that caused the fires but by having the outlet in the drawer, the user doesn't have to unplug it to put it away.
Both cases the homeowner commented that it was a dumb idea.
Just my $.02
Just my $.02
You have a heat producing item in a drawer, and drawers are often "catch -all" for who knows what that may be ignitable. There doesn't need to be a defect in the product to start a fire.This sounds more like a defective product than a problem with an outlet in a drawer.
Ask them if they would light a candle, place it in the drawer and then close it.
would maybe only agree to a USB charging port in a drawer.
With the frequency that phones and other lithium ion battery devices are catching fire, I'm not even sure that's a good idea. I no longer leave items charging all over the house. I keep them where I can see them.
Just my $.02
This one says it has a thermostat.
https://www.amazon.com/Style-Drawer-In-Drawer-Outlet-Thermostat/dp/B00MBPABRO
We have one of these in the shop now to install soon. Purchased through Graybar.
I don't think I would want to install anything without a thermostat of some kind to kill power if the temperature got to hot.
Link to dockingdrawer website: http://www.dockingdrawer.com/
Link to pdf (page 2) stating thermostat cut off at 120 degrees: http://go.dockingdrawer.com/hubfs/L...5fbaba2d|faf8630b-0985-4721-bf97-90674b7b3744
Curling irons, that are a concern here, would hold on a 1 amp breaker.I know I have seen a purpose-built receptacle for in-drawer mounting. It had a built in circuit breaker, maybe 1A, so that it could only be used with low-current devices.
Haven't looked at one in a while, but seems around 30-40 watts is pretty typical.My wife doesn't own one, so I'm not terribly familiar with them, but looking on line it seems they have a much lower draw than hair dryers. I can believe you'd be good with that.
